The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver audit audit-log-redirect create
PDF of this doc site
Creating your file...
Your file is ready
Create Audit Log Redirect Vserver destination
The vserver audit audit-log-redirect create
command creates an audit log redirect configuration to designate a dedicated Vserver for all audit logs in a cluster to reside in.
-vserver <vserver name>
- Audit Log Redirect Vserver (privilege: advanced)-
Use this parameter to specify a dedicated Vserver for all audit logs to reside in.
The following example causes all audit logs in a cluster to be redirected to vserver1
cluster1::> vserver audit audit-log-redirect create -vserver vserver1
