vserver audit audit-log-redirect create
Create Audit Log Redirect Vserver destination
The vserver audit audit-log-redirect create
command creates an audit log redirect configuration to designate a dedicated Vserver for all audit logs in a cluster to reside in.
-vserver <vserver name>
- Audit Log Redirect Vserver (privilege: advanced)-
Use this parameter to specify a dedicated Vserver for all audit logs to reside in.
The following example causes all audit logs in a cluster to be redirected to vserver1
cluster1::> vserver audit audit-log-redirect create -vserver vserver1
