volume unmount
PDF of this doc site
Creating your file...
Your file is ready
Unmount a volume
The volume unmount
command unmounts a volume from its parent volume. The volume can be remounted at the same or a different location by using the volume mount command.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the volume that is to be unmounted.
The following example unmounts a volume named vol2 on a Vserver named vs0:
node::> volume unmount -vserver vs0 -volume vol2
