ONTAP commands
volume unmount
Unmount a volume
The volume unmount command unmounts a volume from its parent volume. The volume can be remounted at the same or a different location by using the volume mount command.
-vserver <vserver name> - Vserver Name
This specifies the Vserver on which the volume is located.
-volume <volume name> - Volume Name
This specifies the volume that is to be unmounted.
The following example unmounts a volume named vol2 on a Vserver named vs0:
node::> volume unmount -vserver vs0 -volume vol2
