vserver cifs cache sid-to-name delete
PDF of this doc site
![](/us-en/ontap-cli-9131/images/pdf-zip.png)
Creating your file...
Your file is ready
Delete an entry
The vserver cifs cache sid-to-name delete
command removes the Windows user cache entries cached by security identifier (SID). If cache propagation is enabled, the corresponding name-to-sid cache entry will also be removed.
-vserver <vserver name>
- Vserver (privilege: advanced)-
Use this parameter to specify the Vserver for which the sid-to-name cache entry needs to be deleted.
-sid <text>
- SID (privilege: advanced)-
Use this parameter to specify the security identifier (SID) for which the cached entry needs to be deleted.
The following example shows how to delete the sid-to-name cache entry for Vserver vs0 with SID S-1-5-21-1380078113-1824080971-954447143-1152:
cluster1::> vserver cifs cache sid-to-name delete -vserver vs0 -sid S-1-5-21-1380078113-1824080971-954447143-1152
