The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume recovery-queue purge
PDF of this doc site
Creating your file...
Your file is ready
Purge volumes from the recovery queue belonging to a Vserver
The volume recovery-queue purge
command purges a volume from the recovery queue belonging to a Vserver.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name (privilege: advanced)-
This specifies the volume that is to be purged from the recovery queue.
The following example purges a volume named vol1_1234 on a Vserver named vs1 from the recovery queue.
cluster1::*> volume recovery-queue purge -vserver vs1 -volume vol1_1234
