volume recovery-queue purge
Purge volumes from the recovery queue belonging to a Vserver
The volume recovery-queue purge command purges a volume from the recovery queue belonging to a Vserver.
-vserver <vserver name>- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name (privilege: advanced)-
This specifies the volume that is to be purged from the recovery queue.
The following example purges a volume named vol1_1234 on a Vserver named vs1 from the recovery queue.
cluster1::*> volume recovery-queue purge -vserver vs1 -volume vol1_1234
