system health config show
PDF of this doc site
Creating your file...
Display system health configuration
The system health config show
command displays the configuration and status of each health monitor in the cluster. The command shows a health status for each health monitor. The health status is an aggregation of the subsystem health for each subsystem that the health monitor monitors. For example, if a health monitor monitors two subsystems and the health status of one subsystem is "ok" and the other is "degraded", the health status for the health monitor is "degraded".
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Use this parameter to list the health monitors present on the specified node.
[-monitor <hm_type>]
- Monitor-
Use this parameter to display the health monitors with the specified monitor name.
[-subsystem <hm_subsystem>,…]
- Subsystem-
Selects the health monitors with the specified subsystems.
[-health {ok|ok-with-suppressed|degraded|unreachable|unknown}]
- Health-
Selects the health monitors with the specified health status.
[-mon-version <text>]
- Monitor Version-
Selects the health monitors with the specified monitor version.
[-pol-version <text>]
- Policy File Version-
Selects the health monitors with the specified health monitor policy version.
[-context {Node |Cluster}]
- Context-
Selects the health monitors with the specified running context.
[-aggregator <hm_type>]
- Aggregator-
Selects the health monitors with the specified aggregator.
[-resources <text>,…]
- Resource-
Selects the health monitors with the specified resource name.
[-init-state {Invalid|Initailizing|Initialized|Starting_Discovery|Starting_Re-Discovery|Discovery_Done_Partially|Discovery_Done}]
- Subsystem Initialization Status-
Selects the health monitors with the specified subsystem initialization state.
[-sub-pol-versions <text>]
- Subordinate Policy Versions-
Selects the health monitors with the specified subordinate policy version.
The example below displays information about health monitor configuration:
cluster1::> system health config show Node Monitor Subsystem Health ------------- ---------------------- ----------------- ------------------ node1 node-connect SAS-connect degraded node1 system-connect SAS-connect degraded node1 system SAS-connect degraded
The example below displays detailed information about health monitor configuration:
cluster1::> system health config show -instance Node: node1 Monitor: node-connect Subsystem: SAS-connect Health: degraded Monitor Version: 1.0 Policy File Version: 1.0 Context: node_context Aggregator: system-connect Resource: SasAdapter, SasDisk, SasShelf Subsystem Initialization Status: initialized Subordinate Policy Versions: 1.0 SAS, 1.0 SAS multiple adapters
