system health config show
Display system health configuration
The system health config show command displays the configuration and status of each health monitor in the cluster. The command shows a health status for each health monitor. The health status is an aggregation of the subsystem health for each subsystem that the health monitor monitors. For example, if a health monitor monitors two subsystems and the health status of one subsystem is "ok" and the other is "degraded", the health status for the health monitor is "degraded".
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Use this parameter to list the health monitors present on the specified node.
- [-monitor <hm_type>]- Monitor
Use this parameter to display the health monitors with the specified monitor name.
- [-subsystem <hm_subsystem>,…]- Subsystem
Selects the health monitors with the specified subsystems.
- [-health {ok|ok-with-suppressed|degraded|unreachable|unknown}]- Health
Selects the health monitors with the specified health status.
- [-mon-version <text>]- Monitor Version
Selects the health monitors with the specified monitor version.
- [-pol-version <text>]- Policy File Version
Selects the health monitors with the specified health monitor policy version.
- [-context {Node |Cluster}]- Context
Selects the health monitors with the specified running context.
- [-aggregator <hm_type>]- Aggregator
Selects the health monitors with the specified aggregator.
- [-resources <text>,…]- Resource
Selects the health monitors with the specified resource name.
- [-init-state {Invalid|Initailizing|Initialized|Starting_Discovery|Starting_Re-Discovery|Discovery_Done_Partially|Discovery_Done}]- Subsystem Initialization Status
Selects the health monitors with the specified subsystem initialization state.
- [-sub-pol-versions <text>]- Subordinate Policy Versions
Selects the health monitors with the specified subordinate policy version.
The example below displays information about health monitor configuration:
cluster1::> system health config show Node Monitor Subsystem Health ------------- ---------------------- ----------------- ------------------ node1 node-connect SAS-connect degraded node1 system-connect SAS-connect degraded node1 system SAS-connect degraded
The example below displays detailed information about health monitor configuration:
cluster1::> system health config show -instance
Node: node1
                               Monitor: node-connect
                             Subsystem: SAS-connect
                                Health: degraded
                       Monitor Version: 1.0
                   Policy File Version: 1.0
                               Context: node_context
                            Aggregator: system-connect
                              Resource: SasAdapter, SasDisk, SasShelf
       Subsystem Initialization Status: initialized
           Subordinate Policy Versions: 1.0 SAS, 1.0 SAS multiple adapters
 PDFs
PDFs
