network fcp zone show
PDF of this doc site
Creating your file...
Display the active zone set information
Displays the active zone set information.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Use this parameter to select the active zone set information for adapters that located on the node name that you specify.
[-adapter <text>]
- Adapter-
Use this parameter to select the active zone set information for the specified adapter.
[-zoneset-name <text>]
- Zoneset Name-
Use this parameter to select the active zone set information for the specified zone set name.
[-zone-name <text>]
- Zone Name-
Use this parameter to select the active zone set information for the specified zone name.
[-type-name <text>]
- Type Name-
Use this parameter to select the active zone set information with the specified symbolic type.
[-type <integer>]
- Type-
Use this parameter to select the active zone set information with the specified port type.
[-port-id <Hex Integer>]
- Member Port Id-
Use this parameter to select the active zone set information with the specified member port id.
[-domain-id <integer>]
- Member Domain Id-
Use this parameter to select the active zone set information with the specified member domain id.
[-port <integer>]
- Member Port-
Use this parameter to select the active zone set information with the specified member port.
[-wwn <text>]
- Member WWN-
Use this parameter to select the active zone set information with the specified member WWN.
[-zone-count <integer>]
- Zone Count-
Use this parameter to select the active zone set information with the specified number of zones.
[-zone-member-count <integer>]
- Zone Member Count-
Use this parameter to select the active zone set information with the specified number of zone members in a zone.
[-contents <text>]
- Member Contents-
Use this parameter to select the active zone set information using any type.
cluster1::> network fcp adapter zone show Member Zone Name Type WWN --------------------- ------------------ ------------------- ----------------- Active Zone Set on adapter 0c Zone Set Name: zoneset_name zone_name_1 Port ID - zone_name_1 Port ID - zone_name_1 Port ID - zone_name_2 Domain ID/Port - zone_name_2 Domain ID/Port - zone_name_2 Domain ID/Port - zone_name_3 Fabric Port Name 00:00:00:00:00:00:00:00 zone_name_3 Fabric Port Name 01:00:00:00:00:00:00:00 zone_name_3 Fabric Port Name 02:00:00:00:00:00:00:00 9 entries were displayed.
The example above displays information regarding active zone set information for the cluster.
