network fcp zone show
Display the active zone set information
Displays the active zone set information.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Use this parameter to select the active zone set information for adapters that located on the node name that you specify.
- [-adapter <text>]- Adapter
Use this parameter to select the active zone set information for the specified adapter.
- [-zoneset-name <text>]- Zoneset Name
Use this parameter to select the active zone set information for the specified zone set name.
- [-zone-name <text>]- Zone Name
Use this parameter to select the active zone set information for the specified zone name.
- [-type-name <text>]- Type Name
Use this parameter to select the active zone set information with the specified symbolic type.
- [-type <integer>]- Type
Use this parameter to select the active zone set information with the specified port type.
- [-port-id <Hex Integer>]- Member Port Id
Use this parameter to select the active zone set information with the specified member port id.
- [-domain-id <integer>]- Member Domain Id
Use this parameter to select the active zone set information with the specified member domain id.
- [-port <integer>]- Member Port
Use this parameter to select the active zone set information with the specified member port.
- [-wwn <text>]- Member WWN
Use this parameter to select the active zone set information with the specified member WWN.
- [-zone-count <integer>]- Zone Count
Use this parameter to select the active zone set information with the specified number of zones.
- [-zone-member-count <integer>]- Zone Member Count
Use this parameter to select the active zone set information with the specified number of zone members in a zone.
- [-contents <text>]- Member Contents
Use this parameter to select the active zone set information using any type.
cluster1::> network fcp adapter zone show
                                          Member
                       Zone Name          Type                WWN
Active Zone Set on adapter 0c
   Zone Set Name: zoneset_name
                       zone_name_1        Port ID             -
                       zone_name_2        Domain ID/Port      -
                       zone_name_3        Fabric Port Name    00:00:00:00:00:00:00:00
                       zone_name_3        Fabric Port Name    01:00:00:00:00:00:00:00
                       zone_name_3        Fabric Port Name    02:00:00:00:00:00:00:00
9 entries were displayed.
The example above displays information regarding active zone set information for the cluster.
 PDFs
PDFs
