network fcp zone show
Display the active zone set information
Displays the active zone set information.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Use this parameter to select the active zone set information for adapters that located on the node name that you specify.
[-adapter <text>]- Adapter-
Use this parameter to select the active zone set information for the specified adapter.
[-zoneset-name <text>]- Zoneset Name-
Use this parameter to select the active zone set information for the specified zone set name.
[-zone-name <text>]- Zone Name-
Use this parameter to select the active zone set information for the specified zone name.
[-type-name <text>]- Type Name-
Use this parameter to select the active zone set information with the specified symbolic type.
[-type <integer>]- Type-
Use this parameter to select the active zone set information with the specified port type.
[-port-id <Hex Integer>]- Member Port Id-
Use this parameter to select the active zone set information with the specified member port id.
[-domain-id <integer>]- Member Domain Id-
Use this parameter to select the active zone set information with the specified member domain id.
[-port <integer>]- Member Port-
Use this parameter to select the active zone set information with the specified member port.
[-wwn <text>]- Member WWN-
Use this parameter to select the active zone set information with the specified member WWN.
[-zone-count <integer>]- Zone Count-
Use this parameter to select the active zone set information with the specified number of zones.
[-zone-member-count <integer>]- Zone Member Count-
Use this parameter to select the active zone set information with the specified number of zone members in a zone.
[-contents <text>]- Member Contents-
Use this parameter to select the active zone set information using any type.
cluster1::> network fcp adapter zone show
Member
Zone Name Type WWN
Active Zone Set on adapter 0c
Zone Set Name: zoneset_name
zone_name_1 Port ID -
zone_name_2 Domain ID/Port -
zone_name_3 Fabric Port Name 00:00:00:00:00:00:00:00
zone_name_3 Fabric Port Name 01:00:00:00:00:00:00:00
zone_name_3 Fabric Port Name 02:00:00:00:00:00:00:00
9 entries were displayed.
The example above displays information regarding active zone set information for the cluster.
