The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
lun portset add
PDF of this doc site
Creating your file...
Your file is ready
Add iSCSI/FCP LIFs to a portset
This command adds existing iSCSI and FCP LIFs to a portset. To create a new portset, use the lun portset create command.
Use the network interface create command to create new LIFs.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-portset <text>
- Portset Name-
Specifies the portset you want to add the LIFs to.
-port-name <port_name>,…
- LIF or TPG Name-
Specifies the LIF name you want to add to the portset.
cluster1::> portset add -vserver vs1 -portset ps1 -port-name lif1
Adds port lif1 to portset ps1 on Vserver vs1.
