The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security certificate truststore clear
PDF of this doc site
Creating your file...
Your file is ready
Clear the default root certificates from truststore
The security certificate truststore clear
command deletes the pre-installed certificates of the type 'server-ca'. If you delete these certificates, some of the applications performing SSL communication can fail.
The following example removes the default certificate bundle:
cluster1::> security certificate truststore clear
