      security certificate truststore clear
Clear the default root certificates from truststore
The security certificate truststore clear command deletes the pre-installed certificates of the type 'server-ca'. If you delete these certificates, some of the applications performing SSL communication can fail.
The following example removes the default certificate bundle:
cluster1::> security certificate truststore clear
 PDFs
PDFs
