ONTAP 9.13.1 commands
lun transition show
Display the status of LUN transition processing
The lun transition show command displays information about the LUN transition processing status of volumes. If no parameters are specified, the command displays the following information about all volumes:
  • Vserver name
  • Volume name
  • Transition status
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name (privilege: advanced)
Selects the volumes in the specified Vserver.
[-volume <volume name>] - Volume Name (privilege: advanced)
Selects the volumes with the specified name.
[-status {none|complete|failed|active}] - Transition Status (privilege: advanced)
Selects the volumes that match the specified transition status. The possible status values are:
  • active - The volume is in an active SnapMirror transition relationship and not yet transitioned.
  • complete - LUN transition has completed for the volume.
  • failed - LUN transition has failed for the volume.
  • none - The volume did not contain LUNs to transition from Data ONTAP 7-Mode.
[-vserver-uuid <UUID>] - Vserver UUID (privilege: advanced)
Selects the volumes in the Vserver that matches the specified UUID.
[-node <nodename>] - Filer ID (privilege: advanced)
Selects the volumes that match the specified node.
The following example displays LUN transition information for all volumes in a Vserver named vs1 :
cluster1::*> lun transition show -vserver vs1
Vserver              Volume             Transition Status
vs1                  vol0               none
                     vol1               complete
                     vol2               failed
                     vol3               active
4 entries were displayed.
