      vserver cifs delete
Delete a CIFS server.
The vserver cifs delete command deletes a CIFS server.
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver for the CIFS server you want to delete.
 [-force-account-delete {true|false}]- If this is set, the local CIFS configuration will be deleted irrespective of any communication errors. The default value for this field is false.-
This parameter specifies the force-delete of CIFS server irrespective of any communication errors.
The following example deletes the CIFS server from a Vserver named vs1:
cluster1::> vserver cifs delete -vserver vs1
