vserver cifs delete
Delete a CIFS server.
The vserver cifs delete command deletes a CIFS server.
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver for the CIFS server you want to delete.
[-skip-ad-account-delete {true|false}]- If this option is enabled, the local CIFS configuration will be removed without deleting the AD account. The default setting for this field is false.-
This parameter skips the deletion of the AD account and proceeds directly to the deletion of the local CIFS configuration.
The following example deletes the CIFS server from a Vserver named vs1:
cluster1::> vserver cifs delete -vserver vs1
