vserver cifs delete
Delete a CIFS server
The vserver cifs delete command deletes a CIFS server.
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver for the CIFS server you want to delete.
The following example deletes the CIFS server from a Vserver named vs1:
cluster1::> vserver cifs delete -vserver vs1
