storage errors show
PDF of this doc site
Creating your file...
Display storage configuration errors.
The storage errors show
command displays configuration errors with back end storage arrays.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-uid <text>]
- UID-
Selects the disks that match this parameter value.
[-array-name <array name>]
- Array Name-
Selects the disks that have the specified name for the storage array that is connected to the cluster.
[-node {<nodename>|local}]
- Controller Name-
[-disk <disk path name>]
- Disk-
[-serial-number <text>]
- Serial Number-
[-error-id <integer>,…]
- Error ID-
Selects the disks with error-id values that match this parameter value.
[-error-type {onepath|onedomain|control|foreign|toobig|toosmall|invalidblocksize|targetasymmap|deviceassymmap|failovermisconfig|unknown|netapp|fwdownrev|qualfail|diskfail|notallflashdisk}]
- Error Type-
Selects the disks with error types values that match this parameter value.
The following example displays configuration errors seen in the system:
cluster1::> storage errors show Disk: vnv3070f20b:vnci9124s54:1-24.126L23 -------------------- vnci9124s54:1-24.126L23 (600a0b800019e999000036b24bac3983): This array LUN reports an invalid block size and is not usable. Only a block size of 512 is supported.
