ONTAP commands
storage errors show
Display storage configuration errors.
The storage errors show command displays configuration errors with back end storage arrays.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-uid <text>] - UID
Selects the disks that match this parameter value.
[-array-name <array name>] - Array Name
Selects the disks that have the specified name for the storage array that is connected to the cluster.
[-node {<nodename>|local}] - Controller Name
[-disk <disk path name>] - Disk
[-serial-number <text>] - Serial Number
[-error-id <integer>,…​] - Error ID
Selects the disks with error-id values that match this parameter value.
[-error-type {onepath|onedomain|control|foreign|toobig|toosmall|invalidblocksize|targetasymmap|deviceassymmap|failovermisconfig|unknown|netapp|fwdownrev|qualfail|diskfail|notallflashdisk}] - Error Type
Selects the disks with error types values that match this parameter value.
The following example displays configuration errors seen in the system:
cluster1::> storage errors show
Disk: vnv3070f20b:vnci9124s54:1-24.126L23
vnci9124s54:1-24.126L23 (600a0b800019e999000036b24bac3983): This array LUN reports an invalid block size and is not usable. Only a block size of 512 is supported.
