The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cluster ha show
PDF of this doc site
Creating your file...
Your file is ready
Show high-availability configuration status for the cluster
The cluster ha show
command displays the high-availability status of the cluster. Cluster high-availability mode applies only to two-node clusters.
The following example displays the high-availability status for a two-node cluster :
cluster1::> cluster ha show High-Availability Configured: true
