ONTAP 9.13.1 commands
cluster peer ping
Initiate intercluster connectivity test
The cluster peer ping command displays the status of the network mesh used by the peering relationship. The command checks the network connection to each remote IP address known by the cluster. This includes all intercluster addresses. It is possible for a known address to be not present during the ping. These addresses are not checked, but the absence is temporary.
The most useful parameters for diagnosing problems are -count and -packet-size . Use the -count and -packet-size parameters to diagnose problems similarly to how you use them with the standard ping utility.
To display network connection status within a cluster, use the network ping command.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-originating-node {<nodename>|local}] - Node that Initiates Ping
Use this parameter to send the ping from the node you specify.
[-destination-cluster <Cluster name>] - Cluster to Ping
Use this parameter to specify the peer cluster you wish to ping.
[-destination-node <Peer Node Name>] - Node to Ping in Destination Cluster
Use this parameter to specify a specific node in the destination cluster to ping.
[-ip-address <IP Address>] - Active IP Address
Use this parameter to specify the active IP address you wish to ping.
[-count <integer>] - Ping Count
Use this parameter to specify the number of requests to be sent to the destination.
[-status {unknown_node|internal_error|unreachable|session_reachable|interface_reachable}] - Status of Ping Operation
Use this parameter to display only ping results that have the status you specify.
[-timeout <integer>] - Ping Timeout in Seconds
Use this parameter to specify a timeout value in seconds for the ping operation.
[-packet-size <integer>] - Size of Packet
Use this parameter to specify the number of data bytes to be sent in the ping packet.
[-ttl <integer>] - Time to Live/ Number of Hops
Use this parameter to specify the maximum number of network hops a packet may make before it is considered a failure.
[-response-time <double>] - Response Time (ms)
Use this parameter to display only nodes that have the response time (in milliseconds) that you specify. This parameter is most useful when specified with a range of values, such as >500
This example shows a ping of cluster1 and cluster2 from cluster2. All nodes are reachable.
cluster2::> cluster peer ping
Node: node1                  Destination Cluster: cluster2
Destination Node IP Address       Count  TTL RTT(ms) Status
node1            10.98.228.230        1  255   0.209 interface_reachable
node2            10.98.228.234        1  255    0.42 interface_reachable
Node: node2                  Destination Cluster: cluster2
node1            10.98.228.230        1  255   0.358 interface_reachable
node2            10.98.228.234        1  255    0.17 interface_reachable
Node: node1                  Destination Cluster: cluster1
node3            10.98.229.22         1  255   0.336 interface_reachable
node4            10.98.229.29         1  255   0.354 interface_reachable
Node: node2                  Destination Cluster: cluster1
node3            10.98.229.22         1  255   0.354 interface_reachable
node4            10.98.229.29         1  255   0.336 interface_reachable
6 entries were displayed.
