The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver audit audit-log-redirect delete
PDF of this doc site
Creating your file...
Your file is ready
Delete Audit Log Redirect Vserver destination
The vserver audit audit-log-redirect delete
command deletes the dedicated Vserver for all audit logs in a cluster to reside in.
The following example delete the audit-log-redirect Vserver.
cluster1::> vserver audit audit-log-redirect delete
