ONTAP commands
vserver audit audit-log-redirect delete
Delete Audit Log Redirect Vserver destination
The vserver audit audit-log-redirect delete command deletes the dedicated Vserver for all audit logs in a cluster to reside in.
The following example delete the audit-log-redirect Vserver.
cluster1::> vserver audit audit-log-redirect delete
