ONTAP 9.13.1 commands
network connections active show-services
Show a count of the active connections by service
The network connections active show-services command displays the number of active connections by protocol service, organized by node.
Note The results of this command set are refreshed independently every 30 seconds and might not reflect the immediate state of the system.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Use this parameter to display information only about the connections on the node you specify.
[-vserver <vserver>] - Vserver
This parameter is used by the system to break down the output per vserver
[-service <protocol service>] - Protocol Service
Use this parameter to display information only about the connections that use the protocol service you specify. Possible values include: nfs, iscsi, and loopback.
[-count <integer>] - Client Count
Use this parameter to display information only about protocol services with the number of active client connections you specify.
The following example displays information about all protocol services being used by active connections:
cluster1::> network connections active show-services
Node       Vserver Name    Service    Count
node0
           vs1             mount           3
           vs1             nfs            14
           vs1             nlm_v4          4
           vs1             cifs_srv        3
           vs1             port_map       18
           vs2             rclopcp        27
node1
           vs1             nfs             5
           vs2             rclopcp        12
           vs2             nfs             4
           vs2             port_map        8
