network connections active show-services
Show a count of the active connections by service
The network connections active show-services
command displays the number of active connections by protocol service, organized by node.
The results of this command set are refreshed independently every 30 seconds and might not reflect the immediate state of the system. |
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Use this parameter to display information only about the connections on the node you specify.
[-vserver <vserver>]
- Vserver-
This parameter is used by the system to break down the output per vserver
[-service <protocol service>]
- Protocol Service-
Use this parameter to display information only about the connections that use the protocol service you specify. Possible values include: nfs, iscsi, and loopback.
[-count <integer>]
- Client Count-
Use this parameter to display information only about protocol services with the number of active client connections you specify.
The following example displays information about all protocol services being used by active connections:
cluster1::> network connections active show-services Node Vserver Name Service Count --------- -------------- --------- ------ node0 vs1 mount 3 vs1 nfs 14 vs1 nlm_v4 4 vs1 cifs_srv 3 vs1 port_map 18 vs2 rclopcp 27 node1 vs1 nfs 5 vs2 rclopcp 12 vs2 nfs 4 vs2 port_map 8
