storage aggregate relocation show
Display relocation status of an aggregate
The storage aggregate relocation show command displays status of aggregates which were relocated in the last instance of relocation operation.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>, …parameter, the command only displays the fields that you specify. - |
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all entries. [-node {<nodename>|local}]- Node-
Selects aggregates from the specified source node.
[-aggregate <text>]- Aggregate Name-
Selects the aggregates that match this parameter value.
[-relocation-status <text>]- Aggregates Relocation Status-
Selects the aggregates whose relocation status matches this parameter value.
[-destination <text>]- Destination for Relocation-
Selects the aggregates that are designated for relocation on the specified destination node.
The following example displays the relocation status of aggregates on all nodes in the cluster:
cluster1::> storage aggregate relocation show
Source Aggregate Destination Relocation Status
node0
- - Not attempted yet
node1
aggr1 node0 Done
aggr2 node0 In progress
aggr3 node0 Not attempted yet
4 entries were displayed.
