storage aggregate relocation show
Display relocation status of an aggregate
The storage aggregate relocation show
command displays status of aggregates which were relocated in the last instance of relocation operation.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command only displays the fields that you specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all entries. [-node {<nodename>|local}]
- Node-
Selects aggregates from the specified source node.
[-aggregate <text>]
- Aggregate Name-
Selects the aggregates that match this parameter value.
[-relocation-status <text>]
- Aggregates Relocation Status-
Selects the aggregates whose relocation status matches this parameter value.
[-destination <text>]
- Destination for Relocation-
Selects the aggregates that are designated for relocation on the specified destination node.
The following example displays the relocation status of aggregates on all nodes in the cluster:
cluster1::> storage aggregate relocation show Source Aggregate Destination Relocation Status -------------- ---------- ----------- ----------------- node0 - - Not attempted yet node1 aggr1 node0 Done aggr2 node0 In progress aggr3 node0 Not attempted yet 4 entries were displayed.
