Command reference
storage aggregate relocation show
Display relocation status of an aggregate
The storage aggregate relocation show command displays status of aggregates which were relocated in the last instance of relocation operation.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>, …​ parameter, the command only displays the fields that you specify.
| [-instance ] }
If you specify the -instance parameter, the command displays detailed information about all entries.
[-node {<nodename>|local}] - Node
Selects aggregates from the specified source node.
[-aggregate <text>] - Aggregate Name
Selects the aggregates that match this parameter value.
[-relocation-status <text>] - Aggregates Relocation Status
Selects the aggregates whose relocation status matches this parameter value.
[-destination <text>] - Destination for Relocation
Selects the aggregates that are designated for relocation on the specified destination node.
The following example displays the relocation status of aggregates on all nodes in the cluster:
cluster1::> storage aggregate relocation show
Source         Aggregate  Destination   Relocation Status
node0
               -          -             Not attempted yet
node1
               aggr1      node0         Done
               aggr2      node0         In progress
               aggr3      node0         Not attempted yet
4 entries were displayed.
