The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage aggregate reallocation stop
PDF of this doc site
Creating your file...
Your file is ready
Stop reallocate job on aggregate
Stops and deletes any reallocation scan running on the specified aggregate. This command stops and deletes in-progress, scheduled, and quiesced scans.
-aggregate <aggregate name>
- Aggregate Name-
Specify this parameter to specify the target aggregate on which to stop and delete a reallocation scan.
cluster1::> storage aggregate reallocation stop -aggregate aggr0
Stops and deletes the reallocation scan on aggregate aggr0.
