snapmirror failover show
Display failover status
The snapmirror failover show command is used to monitor the progress of the failover operation on the SnapMirror Business Continuity (SMBC) relationship. You must execute this command from the destination cluster of the SMBC relationship.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-start-time <MM/DD/YYYY HH:MM:SS>]- Start Time-
Start operation time of the failover.
[-source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}]- Source Path-
Specifies the source endpoint of the SnapMirror relationship.
[-destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}]- Destination Path-
Specifies the destination endpoint of the SnapMirror relationship.
[-status {started|failed|completed|completed_with_warnings}]- Failover Status-
Ths status of snapmirror failover.
[-error-reason <text>]- Error Reason-
The reason for failure occured during snapmirror failover.
[-end-time <MM/DD/YYYY HH:MM:SS>]- End Time-
End operation time of the failover.
[-primary-data-cluster <text>]- Primary Data Cluster-
Primary data cluster.
[-last-progress-update <text>]- Last Progress Update-
Last progress update.
[-type {planned|unplanned|incapable}]- Failover Type-
Whether the SnapMirror failover was planned or unplanned.
[-error-reason-codes <integer>,…]- Error Reason codes-
The reason codes for failure occured during snapmirror failover.
To see the progress of the failover operation performed on an SMBC relationship with destination Consistency Group cg_dst in Vserver vs2.example.com , type the following command from the destination cluster:
destination::> snapmirror failover show -destination-path
vs2.example.com:/cg/cg_dst
