ONTAP commands
snapmirror failover show
Display failover status
The snapmirror failover show command is used to monitor the progress of the failover operation on the SnapMirror active sync relationship. You must execute this command from the destination cluster of the SnapMirror active sync relationship.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-start-time <MM/DD/YYYY HH:MM:SS>] - Start Time
Start operation time of the failover.
[-source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}] - Source Path
[-destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}] - Destination Path
[-status {started|failed|completed|completed_with_warnings}] - Failover Status
Ths status of SnapMirror failover.
[-error-reason <text>] - Error Reason
The reason for failure occurred during SnapMirror failover.
[-end-time <MM/DD/YYYY HH:MM:SS>] - End Time
End operation time of the failover.
[-primary-data-cluster <text>] - Primary Data Cluster
Primary data cluster.
[-last-progress-update <text>] - Last Progress Update
Last progress update.
[-type {planned|unplanned|incapable}] - Failover Type
Whether the SnapMirror failover was planned or unplanned.
[-error-reason-codes <integer>,…​] - Error Reason codes
The reason codes for failure occurred during SnapMirror failover.
To see the progress of the failover operation performed on an SnapMirror active sync relationship with destination Consistency Group cg_dst in Vserver vs2.example.com , type the following command from the destination cluster:
destination::> snapmirror failover show -destination-path
                vs2.example.com:/cg/cg_dst
