ONTAP commands
volume clone show
Display a list of FlexClones
The volume clone show command displays information about FlexClone clone volumes. This command is only supported for flexible volumes. By default, the command displays the following information about all FlexClone volume clones:
  • Vserver name
  • FlexClone volume name
  • Parent volume name
  • Parent snapshot name
  • Whether a FlexClone volume is online or offline
To display detailed information about all FlexClone volumes, run the command with the -instance parameter.
{ [-fields <fieldname>,…​]
Selects the fields to be displayed.
| [-estimate ]
Displays an estimate of the free disk space required in the aggregate to split the indicated clone volume from its underlying parent volume. The value reported may differ from the space actually required to perform the split, especially if the clone volume is changing when the split is being performed.
| [-instance ] }
Displays detailed information about FlexClone volumes. If -flexclone is also specified, the command displays detailed information about the FlexClone volume.
[-vserver <vserver name>] - Vserver Name
Selects summary information for the FlexClone volumes on the specified Vserver. If -flexclone is also specified, the command displays detailed information about the specified FlexClone volume.
[-flexclone <volume name>] - FlexClone Volume
Selects summary information for the specified FlexClone volume. If -vserver is also specified, the command displays detailed information about the specified FlexClone volume.
[-type {RW|DP}] - FlexClone Type
Selects information for the specified type of FlexClone volume. The type can be specified as either read-only (DP) or read-write (RW).
[-parent-vserver <vserver name>] - FlexClone Parent Vserver
Selects summary information for the FlexClone volumes that are clone volumes in the specified parent Vserver.
[-b, -parent-volume <volume name>] - FlexClone Parent Volume
Selects summary information for the FlexClone volumes that are clones of the specified parent volume.
[-parent-snapshot <snapshot name>] - FlexClone Parent Snapshot
Selects summary information for the FlexClone volumes that are clones of the parent volume to which the specified snapshot belongs.
[-state {online|restricted|offline|force-online|force-offline|mixed}] - FlexClone Volume State
Selects summary information for the FlexClone volumes that are in the specified state.
[-junction-path <junction path>] - Junction Path
Selects summary information for the FlexClone volumes that have the specified junction path.
[-junction-active {true|false}] - Junction Active
Selects summary information for the FlexClone volumes that have the specified junction path status.
[-s, -space-guarantee {none|volume}] - Space Guarantee Style
If this parameter is specified, the command displays information only about the volumes that have the specified space guarantee style.
[-space-guarantee-enabled {true|false}] - Space Guarantee In Effect
Selects summary information for the FlexClone volumes that have the specified space-guarantee setting.
[-aggregate <aggregate name>] - FlexClone Aggregate
Selects summary information for the FlexClone volumes that reside on the specified storage aggregate.
[-dsid <integer>] - FlexClone Data Set ID
Selects summary information for the FlexClone volumes that have the specified Data Set ID.
[-msid <integer>] - FlexClone Master Data Set ID
Selects summary information for the FlexClone volumes that have the specified Master Data Set ID.
[-size {<integer>[KB|MB|GB|TB|PB]}] - FlexClone Size
Selects summary information for the FlexClone volumes that have the specified size.
[-used {<integer>[KB|MB|GB|TB|PB]}] - Used Size
Selects summary information for the FlexClone volumes that have the specified amount of used space.
[-split-estimate {<integer>[KB|MB|GB|TB|PB]}] - Split Estimate
Selects summary information for the FlexClone volumes that require the specified amount of free disk space for splitting from the parent.
[-blocks-scanned <integer>] - Blocks Scanned
Selects summary information for the FlexClone volumes that have the specified number of blocks scanned for splitting the FlexClone volume from its parent volume.
[-blocks-updated <integer>] - Blocks Updated
Selects summary information for the FlexClone volumes that have the specified number of blocks updated for after splitting the FlexClone volume from its parent volume.
[-comment <text>] - Comment
Selects summary information for the FlexClone volumes that have the specified comment.
[-qos-policy-group <text>] - QoS Policy Group Name
Selects summary information for the FlexClone volumes that have the specified QoS policy group.
[-qos-adaptive-policy-group <text>] - QoS Adaptive Policy Group Name
Selects summary information for the FlexClone volumes that have the specified QoS adaptive policy group.
[-caching-policy <text>] - Caching Policy Name
This optionally specifies the caching policy to apply to the volume. A caching policy defines how the system caches this volume's data in Flash Cache modules. If a caching policy is not assigned to this volume, the system uses the caching policy that is assigned to the containing Vserver. If a caching policy is not assigned to the containing Vserver, the system uses the default cluster-wide policy. The available caching policies are:
  • none - Does not cache any user data or metadata blocks.
  • auto - Read caches all metadata and randomly read user data blocks, and write caches all randomly overwritten user data blocks.
  • meta - Read caches only metadata blocks.
  • random_read - Read caches all metadata and randomly read user data blocks.
  • random_read_write - Read caches all metadata, randomly read and randomly written user data blocks.
  • all_read - Read caches all metadata, randomly read, and sequentially read user data blocks.
  • all_read_random_write - Read caches all metadata, randomly read, sequentially read and randomly written user data.
  • all - Read caches all data blocks read and written. It does not do any write caching.
  • noread-random_write - Write caches all randomly overwritten user data blocks. It does not do any read caching.
  • meta-random_write - Read caches all metadata and write caches randomly overwritten user data blocks.
  • random_read_write-random_write - Read caches all metadata, randomly read and randomly written user data blocks. It also write caches randomly overwritten user data blocks.
  • all_read-random_write - Read caches all metadata, randomly read, and sequentially read user data blocks. It also write caches randomly overwritten user data blocks.
  • all_read_random_write-random_write - Read caches all metadata, randomly read, sequentially read and randomly written user data. It also write caches randomly overwritten user data blocks.
  • all-random_write - Read caches all data blocks read and written. It also write caches randomly overwritten user data blocks.
Note that in a caching-policy name, a hyphen (-) separates read and write policies. Default caching-policy is auto.
[-parent-vol-type <volAccessType>] - Parent volume type (privilege: advanced)
Selects summary information for the FlexClone volumes that are clones of the parent volumes with the specified type.
[-flexclone-used-percent <percent>] - FlexClone Used Percentage
Selects summary information for the FlexClone volumes that have the specified percentage of used space.
[-vserver-dr-protection {protected|unprotected}] - Vserver DR Protection
Selects summary information for the FlexClone volumes that have the specified type of Vserver SnapMirror protection. This parameter is applicable only if the Vserver is the source of a Vserver level SnapMirror relationship.
[-block-percentage-complete <integer>] - Percentage Complete
Selects summary information for the FlexClone volumes that have specified percentage of Blocks processed for splitting the FlexClone volume from its parent volume.
[-uid <integer>] - Volume-Level UID
Selects summary information for the FlexClone volumes that are created with the specified volume-level UID.
[-gid <integer>] - Volume-Level GID
Selects summary information for the FlexClone volumes that are created with the specified volume-level GID.
[-flexgroup-uuid <UUID>] - UUID of the FlexGroup
If this parameter is specified, the command displays information only about the FlexGroup volume or FlexGroup volume constituents that have the specified FlexGroup volume UUID. This parameter applies to FlexGroup volumes and FlexGroup volume constituents only.
[-flexgroup-msid <integer>] - FlexGroup Master Data Set ID
If this parameter is specified, the command displays information only about the FlexGroup volume or FlexGroup volume constituents that have the specified FlexGroup volume master data-set ID. This parameter applies to FlexGroup volumes and FlexGroup volume constituents only.
[-flexgroup-index <integer>] - FlexGroup Index
If this parameter is specified, the command displays information only about the FlexGroup volume constituents that have the specified FlexGroup volume index. This parameter applies to FlexGroup volume constituents only.
[-max-constituent-size {<integer>[KB|MB|GB|TB|PB]}] - Maximum size of a FlexGroup Constituent
If this parameter is specified, the command displays information only about the FlexGroup volume or FlexGroup volumes that have the specified maximum constituent size. This parameter applies to FlexGroup volumes only.
[-constituent-role <Constituent Roles>] - Constituent Volume Role
If this parameter is specified, the command displays information only about the constituent volume or volumes that are of the specified role. This parameter applies to FlexGroup volumes only.
[-is-flexgroup-constituent-active {true|false}] - Is Active FlexGroup Constituent
If this parameter is specified, the command displays information only about the volume or volumes that are either active constituent of the FlexGroup or not, depending on the value provided.
[-is-constituent {true|false}] - Is Constituent Volume
If this parameter is specified, the command displays information only about volumes that either are or are not constituents of a FlexGroup, depending on the value provided.
[-is-flexgroup {true|false}] - Is Volume a FlexGroup
If this parameter is specified, the command displays information only about the volume or volumes that are either FlexGroups or not, depending on the value provided.
[-volume-style-extended {flexvol|flexgroup|flexgroup-constituent}] - Extended Volume Style
If this parameter is specified, the command displays information only about the volumes that are configured with the specified extended style. Possible values are flexvol for FlexVol volumes, flexgroup for FlexGroups and flexgroup-constituent for FlexGroup constituents.
[-snaplock-type {non-snaplock|compliance|enterprise}] - SnapLock Type
Selects summary information for the FlexClone volumes that are created with the specified SnapLock type.
The following example displays detailed information about all FlexClone volumes on Vserver vs0 :
cluster1::> volume clone show -vserver vs0
  (volume clone show)
Vserver   FlexClone      Parent-Volume   Parent-Snapshot
vs0       fc_vol_1       test_vol        clone_fc_vol_1.0
          fc_vol_2       test_vol2       clone_fc_vol_2.0
          fc_vol_3       tv9             clone_fc_vol_3.0
          tv8            tv7             clone_tv8.0
          tv9            test_vol2       clone_tv9.0
5 entries were displayed.
The following example displays detailed information about FlexClone volume fc_vol_2 on Vserver vs0 :
cluster1::> volume clone show -vserver vs0 -flexclone fc_vol_2
Vserver Name: vs0
            FlexClone Volume: fc_vol_2
     FlexClone Parent Volume: test_vol2
   FlexClone Parent Snapshot: clone_fc_vol_2.0
               Junction Path: -
             Junction Active: -
       Space Guarantee Style: volume
   Space Guarantee In Effect: true
         FlexClone Aggregate: test_aggr
       FlexClone Data Set ID: 1038
FlexClone Master Data Set ID: 2147484686
              FlexClone Size: 47.50MB
                   Used Size: 128KB
              Split Estimate: 0.00B
            Inodes processed: -
                Total Inodes: -
   Inode Percentage complete: -
              Blocks Scanned: -
              Blocks Updated: -
                     Comment:
       Qos Policy Group Name: pg1
FlexClone Parent Volume Type: RW
   Block Percentage complete: -
The following example displays summary information about all FlexClone volumes residing on Vserver vs0 along with the fields msid , dsid , state and parent-volume .
cluster1::> volume clone show -vserver vs0 -fields msid, dsid, state, parent-volume
vserver flexclone parent-volume state  dsid msid
vs0     fc_vol_1  test_vol      online 1037 2147484685
vs0     fc_vol_3  tv9           online 1039 2147484687
vs0     flex_clone1
                  fc_vol_1      online 1041 2147484689
vs0     fv_2      fc_vol_1      online 1043 2147484691
vs0     tv9       test_vol2     online 1036 2147484684
The following example displays summary information about all FlexClone volumes residing on Vserver vs0 along with space-guarantee-enabled and space-guarantee information about each FlexClone volume.
cluster1::> vol clone show -vserver vs0 -fields space-guarantee-enabled, space-guarantee
  (volume clone show)
vserver flexclone space-guarantee space-guarantee-enabled
vs0     fc_vol_1  volume          true
vs0     fc_vol_3  volume          true
vs0     flex_clone1
                  volume          true
vs0     fv_2      volume          true
vs0     tv9       volume          true
