The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver peer permission delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a Vserver peer permission
The vserver peer permission delete
command deletes Vserver peer permissions.
-peer-cluster <text>
- Peer Cluster Name-
Specifies the name of the peer Cluster.
-vserver <text>
- Vserver Name-
Specifies the name of the local Vserver.
The following example illustrates how to delete Vserver peer permissions:
cluster1::> vserver peer permission delete -peer-cluster cluster2 -vserver vs1
