Command reference
vserver peer permission delete
Delete a Vserver peer permission
The vserver peer permission delete command deletes Vserver peer permissions.
-peer-cluster <text> - Peer Cluster Name
Specifies the name of the peer Cluster.
-vserver <text> - Vserver Name
Specifies the name of the local Vserver.
The following example illustrates how to delete Vserver peer permissions:
cluster1::> vserver peer permission delete -peer-cluster cluster2 -vserver vs1
