volume move target-aggr show
PDF of this doc site
Creating your file...
List target aggregates compatible for volume move
The volume move target-aggr show displays information about compatible target aggregates for the specified volume to be moved to.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name (Required field)-
Selects information about compatible target aggregates for volumes of the specified Vserver.
[-volume <volume name>]
- Volume Name (Required field)-
Selects information about compatible target aggregates that have enough space for the specified volume.
[-aggregate <aggregate name>]
- Aggregate Name-
Selects information about compatible target aggregates with the specified aggregate name (to which the volume might be moved).
[-tiering-policy <Tiering Policy>]
- Volume Tiering Policy-
Selects information about compatible target aggregates with the specified destination tiering policy.
[-availsize {<integer>[KB|MB|GB|TB|PB]}]
- Available size-
Selects information about compatible target aggregates that have the specified available size.
[-storagetype <text>]
- Storage Type-
Selects information about compatible target aggregates with the specified storage type. Examples of storage types are “ATA”, ”BSAS”, “FCAL”, “LUN”, “SATA”, “SAS” and “SSD”.
[-allow-mixed-aggr-types {true|false}]
- Allow Mixing FabricPool and non-FabricPool-
If set to true, moving a FlexGroup constituent from a FabricPool to a non-FabricPool, or vice versa, is allowed. The default value is false. This parameter is only supported for FlexGroup constituents.
The following example lists target aggregates compatible for moving a volume vol1 on a Vserver vs1.
cluster1::> volume move target-aggr show -vserver vs1 -volume vol1 Aggregate Name Available Size Storage Type -------------- -------------- ------------ aggr1 113.5GB FCAL aggr2 113.5GB FCAL 2 entries were displayed.
