volume move target-aggr show
List target aggregates compatible for volume move
The volume move target-aggr show displays information about compatible target aggregates for the specified volume to be moved to.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Name (Required field)
Selects information about compatible target aggregates for volumes of the specified Vserver.
- [-volume <volume name>]- Volume Name (Required field)
Selects information about compatible target aggregates that have enough space for the specified volume.
- [-aggregate <aggregate name>]- Aggregate Name
Selects information about compatible target aggregates with the specified aggregate name (to which the volume might be moved).
- [-tiering-policy <Tiering Policy>]- Volume Tiering Policy
Selects information about compatible target aggregates with the specified destination tiering policy.
- [-availsize {<integer>[KB|MB|GB|TB|PB]}]- Available size
Selects information about compatible target aggregates that have the specified available size.
- [-storagetype <text>]- Storage Type
Selects information about compatible target aggregates with the specified storage type. Examples of storage types are “ATA”, ”BSAS”, “FCAL”, “LUN”, “SATA”, “SAS” and “SSD”.
- [-allow-mixed-aggr-types {true|false}]- Allow Mixing FabricPool and non-FabricPool
If set to true, moving a FlexGroup constituent from a FabricPool to a non-FabricPool, or vice versa, is allowed. The default value is false. This parameter is only supported for FlexGroup constituents.
The following example lists target aggregates compatible for moving a volume vol1 on a Vserver vs1.
cluster1::> volume move target-aggr show -vserver vs1 -volume vol1
    Aggregate Name   Available Size   Storage Type
    aggr1            113.5GB          FCAL
    aggr2            113.5GB          FCAL
    2 entries were displayed.
 PDFs
PDFs
