The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system bridge coredump delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a saved coredump file.
The system bridge coredump delete
command deletes a coredump file previously retrieved with the system bridge coredump collect command.
-name <text>
- Bridge Name-
This parameter specifies the name of the bridge that the coredump file belongs to.
-corename <text>
- Coredump Filename-
This parameter specifies the name of the coredump file to be deleted.
The following example deletes coredump file core.FB7500N100018.1970-01-05.17_50_30.mem collected from bridge ATTO_FibreBridge7500N_1:
cluster1::> system bridge coredump delete -name ATTO_FibreBridge7500N_1 -corename core.FB7500N100018.1970-01-05.17_50_30.mem cluster1::>
