system bridge coredump delete
Delete a saved coredump file.
The system bridge coredump delete
command deletes a coredump file previously retrieved with the system bridge coredump collect command.
-name <text>
- Bridge Name-
This parameter specifies the name of the bridge that the coredump file belongs to.
-corename <text>
- Coredump Filename-
This parameter specifies the name of the coredump file to be deleted.
The following example deletes coredump file core.FB7500N100018.1970-01-05.17_50_30.mem collected from bridge ATTO_FibreBridge7500N_1:
cluster1::> system bridge coredump delete -name ATTO_FibreBridge7500N_1 -corename core.FB7500N100018.1970-01-05.17_50_30.mem cluster1::>
