vserver services access-check authentication ontap-admin-login-cifs
Authenticate Data ONTAP admin CIFS user
The vserver services access-check authentication ontap-admin-login-cifs command authenticates the Data ONTAP administrator's user through the specified node using the specified Vserver's configuration. Upon success, it displays the user's Windows credentials.
[-node {<nodename>|local}]- Node (privilege: advanced)-
The name of the node on which the command is executed.
 -vserver <vserver>- Vserver (privilege: advanced)-
The name of a Vserver with a configured CIFS server.
 -user <text>- User Name (privilege: advanced)-
The name of a user that is a member of the Windows or a trusted domain that the CIFS server in the specified Vserver belongs to.
 [-clientIp <IP Address>]- Client IP Address (privilege: advanced)-
The IP address of the client as specified by the user
This example authenticates the Data ONTAP administrator user "administrator" through node "node2" using the configuration of Vserver "vs1." Upon success, it displays the CIFS credentials for "administrator."
cluster1::vserver services access-check*> authentication ontap-admin-login-cifs -vserver vs1 -user administrator -node node2
Enter the password:
Windows User: administrator Domain: EXAMPLE Privs: a7
 Primary Grp: S-1-5-21-1407423728-2963865486-1834115207-513
      Domain: S-1-5-21-1407423728-2963865486-1834115207 Rids: 500, 520, 513, 22226, 26625, 1842, 512, 519, 518, 8323, 1645, 1648, 1644, 1647, 1003
      Domain: S-1-1 Rids: 0
      Domain: S-1-5 Rids: 11, 2
Authentication Succeeded.
