The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network port vlan create
PDF of this doc site
Creating your file...
Your file is ready
Create a virtual LAN (VLAN)
The network port vlan create
command attaches a VLAN to a network port on a specified node.
-node {<nodename>|local}
- Node-
The node to which the VLAN is to be attached.
You cannot attach a VLAN to a cluster port. - {
-vlan-name {<netport>|<ifgrp>}
- VLAN Name -
The name of the VLAN that is to be attached. This name should be a combination of the name of the port or interface group and the VLAN ID, with a hyphen between, such as "e1c-80".
-port {<netport>|<ifgrp>}
- Associated Network Port -
The network port to which the VLAN is to be attached.
-vlan-id <integer>
- Network Switch VLAN Identifier }-
The ID tag of the created VLAN.
[-skip-broadcast-domain-placement <true>]
- Skip Placement Into Broadcast Domain (privilege: advanced)-
When specified, the VLAN will not be placed into any broadcast domain.
This example shows how to create VLAN e1c-80 attached to network port e1c on node1.
cluster1::> network port vlan create -node node1 -vlan-name e1c-80
