ONTAP commands
vserver peer resume
Resume a Vserver peer relationship
The vserver peer resume command resumes the Vserver peer relationship between two Vservers.
-vserver <vserver> - Vserver Name
Specifies name of the local Vserver for which you want to resume the Vserver peer relationship.
-peer-vserver <vserver> - Peer Vserver Name
Specifies name of the peer Vserver with which you want to resume the Vserver peer relationship.
[-force <true>] - Force Resume
Resumes the Vserver peer relationship even if the remote cluster is not accessible due to, for example, network connectivity issues.
The following example illustrates resuming a Vserver peer relationship between two Vservers lvs1.example.com residing on cluster1 , and pvs1.example.com residing on cluster2 .
cluster1::> vserver peer resume -vserver lvs1.example.com -peer-vserver pvs1.example.com
