vserver peer resume
Resume a Vserver peer relationship
The vserver peer resume
command resumes the Vserver peer relationship between two Vservers.
-vserver <vserver>
- Vserver Name-
Specifies name of the local Vserver for which you want to resume the Vserver peer relationship.
-peer-vserver <vserver>
- Peer Vserver Name-
Specifies name of the peer Vserver with which you want to resume the Vserver peer relationship.
[-force <true>]
- Force Resume-
Resumes the Vserver peer relationship even if the remote cluster is not accessible due to, for example, network connectivity issues.
The following example illustrates resuming a Vserver peer relationship between two Vservers lvs1.example.com
residing on cluster1
, and pvs1.example.com
residing on cluster2
cluster1::> vserver peer resume -vserver lvs1.example.com -peer-vserver pvs1.example.com
