storage firmware acp delete
PDF of this doc site
Creating your file...
Your file is ready
Delete an ACP firmware file
The storage firmware acp delete
command deletes the specified ACP processor firmware file from all nodes that are currently part of the cluster.
-filename <text>
- Firmware Filename (privilege: advanced)-
Specifies the firmware file to delete.
The following example deletes the ACP processor firmware file with the name ACP-IOM3.0150.AFW.FVF on each node:
cluster1::*> storage firmware acp delete -filename ACP-IOM3.0150.AFW.FVF
