system snmp community show
PDF of this doc site
Creating your file...
Your file is ready
Displays communities
Displays the current list of SNMP communities.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Selects the Vserver to which the SNMP community belongs
[-community-name <text>]
- Community-
Selects the SNMP v1/v2c community string
[-access <ctype>]
- access-
Selects the access type of the SNMP v1/v2c community. Read-only (ro) is the only access type supported
cluster1::> system snmp community show cluster1 ro private
