system snmp community show
Displays communities
Displays the current list of SNMP communities.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Selects the Vserver to which the SNMP community belongs
[-community-name <text>] - Community
Selects the SNMP v1/v2c community string
[-access <ctype>] - access
Selects the access type of the SNMP v1/v2c community. Read-only (ro) is the only access type supported
cluster1::> system snmp community show
cluster1
    ro private
