volume file fingerprint show
Display fingerprint operation status
The volume file fingerprint show command returns information for one or several fingerprint operations. This command requires either -session-id or -vserver and -volume .
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-session-id <integer>]- Session ID of Fingerprint Operation-
If this parameter is specified, the command returns the progress of the fingerprint operation of the specified session-id. The session-id is a unique identifier for the fingerprint operation that is returned when the fingerprint operation is started on a file.
 [-vserver <vserver name>]- Vserver-
-volumemust also be specified. When queried with-vserverand-volume, the command returns the progress of all the fingerprint operations running on that particular volume. [-volume <volume name>]- Volume Name-
-vservermust also be specified. When queried with-vserverand-volume, the command returns the progress of all the fingerprint operations running on that particular volume. [-file </vol/<volume name>/<file path>>]- File Path-
If this parameter is specified, the command returns the progress of all fingerprint operations on the specified file.
 [-operation-status {Unknown|In-Progress|Failed|Aborting|Completed}]- Operation Status-
If this parameter is specified, the command returns the progress of all fingerprint operations with matching status value.
 [-progress-percentage <integer>]- Progress Percentage-
If this parameter is specified, the command returns the progress of all fingerprint operations with matching progress percentage value.
The following example displays the progress of all the fingerprint operations running on volume nfs_slc :
cluster1::> volume file fingerprint show -vserver vs0 -volume nfs_slc
        Progress
File-Path                               Session-ID         Status    Percentage
/vol/nfs_slc/worm                       17104897           Completed        100
/vol/nfs_slc/worm_appedable             17104898           Completed        100
/vol/nfs_slc/regular                    17104899           In-Progress       30
3 entries were displayed.
