volume file fingerprint show
Display fingerprint operation status
The volume file fingerprint show
command returns information for one or several fingerprint operations. This command requires either -session-id
or -vserver
and -volume
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-session-id <integer>]
- Session ID of Fingerprint Operation-
If this parameter is specified, the command returns the progress of the fingerprint operation of the specified session-id. The session-id is a unique identifier for the fingerprint operation that is returned when the fingerprint operation is started on a file.
[-vserver <vserver name>]
- Vserver-
-volume
must also be specified. When queried with-vserver
and-volume
, the command returns the progress of all the fingerprint operations running on that particular volume. [-volume <volume name>]
- Volume Name-
-vserver
and-volume
, the command returns the progress of all the fingerprint operations running on that particular volume. [-file </vol/<volume name>/<file path>>]
- File Path-
If this parameter is specified, the command returns the progress of all fingerprint operations on the specified file.
[-operation-status {Unknown|In-Progress|Failed|Aborting|Completed}]
- Operation Status-
If this parameter is specified, the command returns the progress of all fingerprint operations with matching status value.
[-progress-percentage <integer>]
- Progress Percentage-
If this parameter is specified, the command returns the progress of all fingerprint operations with matching progress percentage value.
The following example displays the progress of all the fingerprint operations running on volume nfs_slc
cluster1::> volume file fingerprint show -vserver vs0 -volume nfs_slc Progress File-Path Session-ID Status Percentage --------------------------------------- ------------------ --------- ---------- /vol/nfs_slc/worm 17104897 Completed 100 /vol/nfs_slc/worm_appedable 17104898 Completed 100 /vol/nfs_slc/regular 17104899 In-Progress 30 3 entries were displayed.
