network interface check cluster-connectivity show
PDF of this doc site
Creating your file...
Display the Cluster Connectivity Log
The network interface check cluster-connectivity show
command displays the cluster check result log.
[-fields <fieldname>,…]
If you specify the
parameter, the command displays only the fields that you specify. - |
[-n ]
(privilege: advanced) -
Selects IP addresses instead of LIF names.
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
Selects cluster health records that match the specified node name.
[-record-number <integer>]
- Record Number (privilege: advanced)-
Selects the cluster health records that match specified record number.
[-date-time {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]
- Record Date (privilege: advanced)-
Selects the cluster health records that match the specified date and time.
[-src-name <text>]
- Source LIF Name (privilege: advanced)-
Selects the cluster health records that match the specified source LIF name.
[-src-addr <IP Address>]
- Source IP Address (privilege: advanced)-
Selects the cluster health records that match the specified source IP address.
[-dst-name <text>]
- Destination LIF Name (privilege: advanced)-
Selects the cluster health records that match the specified destination LIF name.
[-dst-addr <IP Address>]
- Destination IP Address (privilege: advanced)-
Selects the cluster health records that match the specified destination IP address.
[-loss {None|Partial|All}]
- Packet Loss (privilege: advanced)-
Selects the cluster health records that match the specified loss value.
The following example displays the cluster connectivity records.
cluster1::> network interface check cluster-connectivity show Source Destination Packet Node Date LIF LIF Loss ------ -------------------------- --------------- --------------- ----------- node1 8/26/2020 10:35:36 -04:00 node1_clus_1 node1_clus_2 none 8/26/2020 10:35:37 -04:00 node1_clus_1 node2_clus_1 none 8/26/2020 10:35:38 -04:00 node1_clus_1 node2_clus_2 none 8/26/2020 10:35:39 -04:00 node1_clus_2 node1_clus_1 none 8/26/2020 10:35:40 -04:00 node1_clus_2 node2_clus_1 none 8/26/2020 10:35:41 -04:00 node1_clus_2 node2_clus_2 none node2 8/26/2020 10:35:36 -04:00 node2_clus_1 node2_clus_2 none 8/26/2020 10:35:37 -04:00 node2_clus_1 node1_clus_1 none 8/26/2020 10:35:38 -04:00 node2_clus_1 node1_clus_2 none 8/26/2020 10:35:39 -04:00 node2_clus_2 node2_clus_1 none 8/26/2020 10:35:40 -04:00 node2_clus_2 node1_clus_1 none 8/26/2020 10:35:41 -04:00 node2_clus_2 node1_clus_2 none 12 entries were displayed.
